Is My Fuel Pump Bad??
Old May 14, 2006 | 03:21 PM
SentimentalValue's Avatar
I just completed a fuel pressure check at the schrader valve b/c my car has been hesitating when accelerating with a load on the motor. I just completed a tune-up with opti, plugs, wires, coil, O2s, pcv and all was well until I put in the new delco fuel filter then the engine progressively got worse. The fuel pressure was as follows:
Ignition turned on, engine not running: Fuel pressure spikes to 44psi, settles at 42psi.
At Idle: 36psi
Simulated WOT (pulled vacuum line): 44psi
Actual WOT Run with load: 36psi-42psi proportionally with 2000-5000rpm run.
5th gear pull from 1700 rpm: 42psi.
I know on shbox's website he says the fuel pressure should stay between 41-47 psi, so is this reason enough to believe the fuel pump is the source of my problem.
P.S. I hooked the guage up again late last night, and it was reading 34 psi at idle and averaging 38 psi with just normal driving.
Old May 14, 2006 | 03:32 PM
Re: Is My Fuel Pump Bad??
Sorry, just re-read shbox's website and it says 41-47psi when the lines are pressurized and the engine is not running. No need to reply.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
