My car won't rev past 5600 in any gear other than 1st!! Please help
Old May 8, 2003 | 01:23 PM
  #16
PGR's Avatar
PGR
If it really is valve float, shouldn't matter what gear its in, it should happen in all gears, even in nuetral. Try reving the car in neutral, and see if it cuts out.
Sounds like it is fuel related (fuel pump, plugged filter, bad pressure regulator. Or maybe even a CAT that is starting to plug up.
You can check your CAT by using a vaccuum gage on the intake. Take readings at idle, 2000, 3000, 4000, 5000 rpm. If the reading drops at higher rpm, CAT or exhaust is plugged/restricted.
ChrisFrez
Dec 7, 2014 06:01 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Timberwolf
Jul 20, 2002 08:45 AM
