My car wont go above 160*
Old Feb 12, 2007 | 09:21 AM
LT1Squirrel's Avatar
its useful in the summer/when im at the track, but during the winter, my heat doesnt work for **** and my gas mileage is horrible...no matter what stat i have in there, if the car is in motion it will stay pegged at 160, it will heat up fine at idle but once i start moving it begins to plummet...i have the GMPP water pump which i believe is the main contributing factor...now my question, is there any way to somehow block the incoming air?...Or if theres a better suggestion please let me hear it
Old Feb 12, 2007 | 09:46 AM
Javier97Z28's Avatar
Moderator
GMPP water pump is the same as a stock waterpump, no difference whatsoever.
Are you running a 160 stat? If so, swap it out with a stocker in the winter.
Old Feb 12, 2007 | 09:47 AM
Chris 96 WS6's Avatar
Yeah just swap out your t-stat....
Personally I never noticed bad mileage with my 160*...I leave it in all year round.
Old Feb 12, 2007 | 12:34 PM
Are you basing this on the coolant temp gauge reading? If so, you may be mislead by the inconsistant markings on the 93 gauges. All the other years indicate the lower hashmark as 160*F. The 93's have this mismarked as 100*F, leading people to believe the engine is running a lot cooler than it really is. Check it with a scanner to see what the temp really is.
Info from Shoebox's website:
Old Feb 12, 2007 | 12:42 PM
street demon2k3's Avatar
Good info Injuneer, my cars gauge sits like that no matter how I drive it. only time it goes up is when im in real heavy traffic. to original post, my car's heater doesnt work either. it usually takes more than 30 minutes before i feel a little heat, but that's no use becuase I never drive that long anyways.
Old Feb 12, 2007 | 01:31 PM
Jared 3870's Avatar
Yeah, must be something with the 93s, because my 97 would put the heat out, but even when my 93 is warmed up the heat it puts out is just enough to make it tolerable in the cabin on cold day.
Old Feb 12, 2007 | 07:28 PM
Ive tried all the stats i have laying around, stock, 160, 180, no-stat and theres no difference, still sits same temp.
Chris, I notice quite a significant difference depending on the temp. my car is driven in
Injuneer, Nope it sits right on the 2nd mark on the gauge, so i decided to borrow a fellow speed density's laptop to see if the gauge was faulty and no dice, it was spot on
Old Feb 13, 2007 | 08:31 PM
no reason to talk about this anymore, just totaled the car this evening lol
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
