My car hates me
Old Dec 21, 2006 | 02:40 PM
slow_94z's Avatar
My car hates me
Ahhhhh well today I noticed a nice little puddle of coolant under my car after driving it awhile. It seems to be coming from some magical hole under the water pump not really where it connects to the block. But anyway every time I stop and shut the car off it starts leaking out but not when I am driving or ideling. Scary to know that my OPTI might get a little bath every time I drive and shut off my car I don't think she will last long .
Old Dec 21, 2006 | 02:43 PM
LenT1's Avatar
Thats odd. I was thinking weap hole but then it should be spraying out when you drive too??
Old Dec 21, 2006 | 02:44 PM
slow_94z's Avatar
Yes while driving at just sitting I can look and see no leak shut the car off and it starts to pour out its weird.
Old Dec 21, 2006 | 02:46 PM
LenT1's Avatar
That is very weird! I would think anything capable of leaking would be spraying all over the place when the car is running.
Old Dec 21, 2006 | 02:56 PM
slow_94z's Avatar
Please Pray for my OPTI people she is 147k miles old she is very fragile.
Another question where should I go to get another ICM is the stock one good do they even make an after market one?
Old Dec 21, 2006 | 03:57 PM
Ultra_Dog's Avatar
Welcome to the club.
Old Dec 21, 2006 | 04:05 PM
mrmint69's Avatar
Mine only leaked when it was off. I would think 2 times before trying for the 200k opti unless you replaced it recently. You will certainly be getting coolant now and during the replacement on the opti. Be sure to drain the coolant out of the knock sensor if you do. I paid 80 from the dealer. I heard from a lot of people not to waist your time or money on an aftermarket one.
Old Dec 21, 2006 | 04:17 PM
slow_94z's Avatar
Yeah I am going to try and drain the coolant so I don't **** up the OPTI dont have the money to replace it right now. Think it possible to do without messing it up?
Old Dec 21, 2006 | 04:22 PM
BUBBA's Avatar
fabricate yourself something to shield the opti from the leak, unless you can stop the leak. JMHO
Old Dec 21, 2006 | 08:28 PM
97greenie's Avatar
Mine only leaked when the car was shut off until about a week later and it just started dumping while I was driving.I was about a mile from home so I got pretty lucky.
Old Dec 22, 2006 | 02:12 AM
slow_94z's Avatar
Dumb question I know but I should just get the reman W/P from any local parts store that will suit the stock motor just fine?
Old Dec 22, 2006 | 06:09 PM
LT1_383's Avatar
You should be able to shield the opti pretty well from the coolant. I wrap a plastic garbage bag around the opti whenever I have to take the water pump off. Never had an issue and I've done it about 4 or 5 times. If you can afford a new water pump, go for that. Otherwise try and get one with a warranty.
Old Dec 22, 2006 | 07:47 PM
My Red 93Z-28's Avatar
My car did the same thing once, It wouldn't leak until after I shut it off and went into work. Turns out a return line was rusted out and would dump coolant once the engine was shut off. The mechanic said they had it on the lift running and could never spot a leak until they turned the car off, then a puddle would appear.
I can't quite remember where it was, but I think it was underneath the battery box.
Old Dec 31, 2006 | 01:07 PM
JT2007's Avatar
Exclamation Leaking after shutoff
Leaking only after being turned off is more common than you think. On our 1990 Lumina it would only leak after being shutoff at the drain pluyg because it wouldn't seal properly. This is because when you turn off the car, all the pressure you built up is no longer moving, it is then standing pressure at 15 to 18lbs. This sometimes stops leaks from showing up because the coolant passes by too quickly to exit the system and helps to seal up leaks due to the movement. When it stops there is no longer sideways pressure to help seal small leaks. We found that Prestone stop leak did not work and you can try some Bar's Leak fix but make sure your system is clean and flushed or you may end up with a plugged heater core . not fun. then you have to do it all over again!! If after proper flushing and one or two attempts with stop leak, then maybe you should try a water pump or gasket. Hope this helps!
LastChance719
Dec 3, 2014 07:55 PM
USAirman93
Nov 24, 2014 03:37 PM
regular Joe
Aug 10, 2002 07:15 PM
regular Joe
Aug 8, 2002 03:47 PM
regular Joe
Aug 8, 2002 07:53 AM
