My baby won't start
Old Aug 6, 2008 | 08:44 AM
zmanlt1's Avatar
My baby won't start
Well I finally got a chance to pull the cover off my Camaro and pull her out of the garage. I put a brand new battery in her and she has no power. I thought it was the battery so I took it out and had it tested and came back fine. All the cables look good too. My next guess is the computer or maybe a mouse made a chew toy out of my wiring harness. The car has no interior lights and will not turn over. Do you guys have any suggestions?
Old Aug 6, 2008 | 09:23 AM
BUBBA's Avatar
If you don't have any lights, my guess is that your terminal batteries are corroded or you are not getting a ground. Before doing anything else, make sure that your battery is charged and the contacts and wires are good.
I know you said they were okay, but if your car was running before, it should run now, if your battery and connections are good. JMHO
Old Aug 6, 2008 | 09:24 AM
BUBBA's Avatar
Also, make sure your ignition fuses are ok.
Old Aug 6, 2008 | 12:55 PM
zmanlt1's Avatar
The battery does have a full charge. I guess I'll check the fuses and the contacts. The contacts appear to be okay, but I'll double check. Thanks, Tom
Old Aug 7, 2008 | 08:21 AM
zmanlt1's Avatar
All fixed!! I cleaned the red positve terminal block on the fender well and it fired right up. Thanks again.
Old Aug 7, 2008 | 08:37 AM
JoeliusZ28's Avatar
was going to suggest that, had the same problem earlier this week
glad you got it going again
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
