My baby won't start
Well I finally got a chance to pull the cover off my Camaro and pull her out of the garage. I put a brand new battery in her and she has no power. I thought it was the battery so I took it out and had it tested and came back fine. All the cables look good too. My next guess is the computer or maybe a mouse made a chew toy out of my wiring harness. The car has no interior lights and will not turn over. Do you guys have any suggestions?
If you don't have any lights, my guess is that your terminal batteries are corroded or you are not getting a ground. Before doing anything else, make sure that your battery is charged and the contacts and wires are good.
I know you said they were okay, but if your car was running before, it should run now, if your battery and connections are good. JMHO:cool: |
Also, make sure your ignition fuses are ok.
The battery does have a full charge. I guess I'll check the fuses and the contacts. The contacts appear to be okay, but I'll double check. Thanks, Tom
All fixed!! I cleaned the red positve terminal block on the fender well and it fired right up. Thanks again.
Originally Posted by zmanlt1
(Post 5521075)
glad you got it going again :) |
