My 6200 mile oil analysis results with German Castrol 0w30
Re: My 6200 mile oil analysis results with German Castrol 0w30
Originally Posted by captain_foustas
is this oil just as good for other cars ( like mustangs , ls1 and other v8s) or is it specificaly good for lt1s only?
I've seen oil analysis reports with this oil in a number of different engines now and it's worked well in all of them. I'm currently running this oil in my Corvette and in my wife's 2000 Civic, plus my mom and dad are running it in their cars too (mom has a 2001 Golf, dad has a 2004 Volvo XC70) In every engine I've personally put it in, and done oil analysis on, the wear numbers with this oil are significantly better. And the oils it has bettered have been Mobil 1, Royal Purple, Maxlife, for instance.
By the way Brent, what was the name of the additive your father tried?
Can someone post the SKU or barcode number from either a case or a bottle of the German Castrol 0w-30? The autozone local to me doesn't carry it, but they said that they might be able to get their hands on it if I got the barcode number.
Thanks,
Chris
Thanks,
Chris
Patman,
Have you done any analysis on LT1's built with larger bearing clearances?
What kind of oil do you recommend for them?
I'm going to get this done on my dodge 4x4 too
Originally Posted by TCAL95Z
Patman,
For any kind of custom engine I highly recommend you do an oil analysis program in order to help you choose the right oil. It's best to work in conjunction with someone who has experience in this area. On that note, I recommend a guy named Terry Dyson. I get him to interpret my reports for me and he can pinpoint exactly what you need to run in order to get long engine life. Here is his contact info:
http://www.bobistheoilguy.com/terry.html
Originally Posted by bunker
So where is the magnesium comming from? Do you have magnesium valve covers that have rockers rubbing against them?
Originally Posted by eagleknight97
Brent, what do you mean by "snake oil"?
It was here...
http://www.ixldave.com/
After a little hunting I found this...
http://www.lubricationproducts.com/ixl.htm
That's the same bottle so they must have just changed their site URL.
Sure sounds good on the site and they had a few pretty convincing demonstrations with this stuff when my dad saw it... but, doesn't appear to have done anything
Hey Patman, what about mixing different weights together do get something in the middle?
I was running M1 50wt and decided it was a little too thick so I started mixing in a couple quarts of 30wt with each oil changeto bring it down to like 43wt. Does this work as I expected?
Not exactly, because those different viscosities will use different levels of viscosity index improvers, so the mixing of the two doesn't exactly give an exact average.
You're better off just going with Mobil 1 0w40 if you wanted to get something thicker than their 5w30 but thinner than their 15w50.
Mixing of the two won't hurt however, but the problem I have with mixing any 15w50 in is the fact that it'll create a thicker oil on startup. Where if you chose the 0w40, you'd get the best of both worlds, an oil with a good flow on startup, but will also protect better when the engine is warm (compared to the 5w30 & 10w30 that is)
Thanks,
Chris
Thanks,
Chris
Help Please??
I have 89k on my LT1. I'm doing an oil change this weekend. I'm currently running M1 SYN 10W-30, should I switch to M1 0W-40?
DOES ANYONE NEED CASTROL SYNTEC 0w30???
I work at Autozone and we carry it. I made sure it was made in Germany. If anyone needs it and doesn't mind paying shipping it is $5.39 per quart including tax plus shipping. I would give you guys my discount, but I don't get a discount on oil. Let me know if anyone needs it.
