My 383 build
Old Mar 25, 2010 | 04:26 PM
..DAMN..'s Avatar
My 383 build
Ive been building a nice 383 for the last few month's so far my shortblock is completely done and my heads are ordered i was wondering what some of you would think it might dyno.
Heres the run down...
splayed cap's
Lunati crank
Scat 6in forged rods
Icon forged #718 flat top piston's
1.6 rr ls7 lifters
TEA cnced trickflows 220cc 2.08/1.6 valves
Custom grind
Ported intake 58mm TB
Electric water pump
1-3/4 longtubes with cutout and magnaflow catback.
3000 stall
Racetronix fuel pump
42lb injectors
dyno tune
Compression will be right around 11.5.1
Im hoping to hit 450whp what do you guys think with this setup what could i dyno to the wheel's?
Old Mar 25, 2010 | 06:02 PM
97 RedSS's Avatar
440rwhp ball park
Old Mar 25, 2010 | 07:30 PM
rskrause's Avatar
Moderator
Why guess? Anyway, I doubt 450rwhp with that combo. But the only way to tell is to test it.
Good luck.
Rich
Old Mar 25, 2010 | 09:47 PM
Cook Performance's Avatar
Who did the head work? I only install our custom grind billet cams, I am not impressed with the 306.
With the proper head work, tuning, and all other supporting mods 450+ H.P. is easily obtainable.
Jake
CPE
Old Mar 25, 2010 | 10:41 PM
RamAir95TA's Avatar
splayed cap's
Lunati crank
1.6 rr ls7 lifters
Trickflow 195cc ported to 210cc with 2.08/1.6 valves
cc306
Electric water pump
3000 stall
42lb injectors
dyno tune
Crap cam, crap compression. You'll probably get maybe 420whp. You could see alot more with a custom grind cam.
Why on earth do you need such large valves?
Old Mar 25, 2010 | 11:51 PM
..DAMN..'s Avatar
Ok the cam is custom grind its going to be comparable to a 306.
Old Mar 26, 2010 | 12:08 AM
IceMatrix69's Avatar
I would recommend getting a hold of a reputable camshaft supplier and have them grind something that matches your set-up with your ultimate goals in mind. I have used Lloyd Elliot before and his service and product was top notch. But as long as you are getting a custom grind and getting the best cam for your setup you should be fine. Just make sure your have all your specs when you call them, especially valve train.......
Old Mar 27, 2010 | 04:43 PM
..DAMN..'s Avatar
Ok so what would you guy's say is the biggest bottleneck with this setup right now?
Old Mar 27, 2010 | 05:21 PM
bubba4's Avatar
I don't think the cc306 will get you those numbers. Go custom grind.
Old Mar 27, 2010 | 09:08 PM
95Blackhawk's Avatar
Not knowing the flow numbers of your heads and matching a cam based on flow and your RPM operating range you require.
Old Mar 27, 2010 | 09:38 PM
..DAMN..'s Avatar
http://www.totalengineairflow.com/pr...gmhead/tfslt1/
My head package is the one at the bottom the 220cc one.
Flow Data
Intake Exhaust
0.1 69 52
0.2 144 119
0.3 212 182
0.4 263 224
0.5 295 247
0.55 306 253
0.6 307 257
0.65 309 260
0.7 310 262
Flowed @28" H20 on 4.030" bore
Exhaust flowed with 2.00"x4" stack
Old Mar 27, 2010 | 09:40 PM
..DAMN..'s Avatar
Sorry it is just what my builder recomended? It already paid for it though. thought it was alittle big myself i thought we were going to go with 2.05 but like i said its already done.
The camshaft will be a custom grind probably alittle bigger than a cc306 i would like to shift the car around 6500 rpms.
Old Jun 22, 2010 | 03:28 AM
..DAMN..'s Avatar
Hello guy's im back with an update! My head's arrived a few days ago! They are TEA ported trickflows 220cc heads with pac behives and 2.08/1.6 valves.
The cam im running is a custom grind 236/242 59x/59x/112 +4 with CC 1.6 pro mags hardened push rods and ls7 lifters.
Stock LT1 intake port matched with a monoblade TB or a 58mm TB
Please comments welcome! Im wanting around 450rwhp.
Old Jun 22, 2010 | 03:32 AM
..DAMN..'s Avatar
Heres the shortblock
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
