advice on next upgrade
Old Jun 20, 2010 | 10:22 PM
Sporty-X's Avatar
Hello everyone,
i've recently swapped my bottom end from stock 350 to Forged 383. Engine is running fine with LE2 heads and all the classic bolt-ons.
I'm running 31# injectors + Holley twin 52 mm. Is my set-up limied by these 2 parts or should i go to larger injectors and twin 58 ?
Let me know please.
Regards.
Pierre
Old Jun 20, 2010 | 10:33 PM
You don't mention what cam you are running. That will give some indication of the possible max flywheel HP of the engine, and that is what determines injector size.
Old Jun 20, 2010 | 10:56 PM
Sporty-X's Avatar
Hello Injuneer,
you're right. Sorry to forget. My cam = Comp Cams Extreme Duty Roller
236/242 Duration @ .050” 555/576 lift 112 LSA.
I'm running also -16 dished pistons for a 11.5/1 ratio.
Old Jun 22, 2010 | 04:22 AM
Sporty-X's Avatar
ttt
97SSdude
Aug 21, 2015 09:36 AM
canuck94z28
Aug 19, 2015 05:50 PM
Rittmeister
Aug 7, 2015 01:13 AM
realistyc
Jul 28, 2015 07:32 PM
GT what?
Jul 14, 2015 10:17 PM
