MSD Pro Billet LT1 Distributor (Opti)?
Re: MSD Pro Billet LT1 Distributor (Opti)?
Originally Posted by speed_demon24
It's kind of like how everyone on here has LE heads, its like no other head porters exist on this website. And I'm not dissing LE heads, they are badass heads, just using it as an example on everyone follows trends, its kind of funny.
Do you have any proof that they use the same parts? Too many people assume **** on here and pass on the wrong info, it gets kind of old. If someone has proof and knows for sure i have no problem with that info. It's kind of like how everyone on here has LE heads, its like no other head porters exist on this website. And I'm not dissing LE heads, they are badass heads, just using it as an example on everyone follows trends, its kind of funny.
I think it is a very safe bet that they are. I mean, whose cap and rotor would they use? Are you assuming they are using someone else's cap painted up with an MSD logo stuck on it?
calling MSD...
[caller] Hello, I am calling to find out if you use your cap and rotor on your Billet Optispark?
[MSD] pause...and muffled voice...Hey boss, come and listen to this, I think I've got a live one!!!
Originally Posted by from MSD product website
Finally, an all-out performance distributor to replace the OEM GM LT-1 Optispark! We machine an entire billet block of aluminum down into a precise housing that fits in place of the factory piece. Then, we fill it with a reliable new pickup assembly, a trick timing adjustment mechanism and top it off with an all new MSD distributor cap!
The pickup is an advanced optical encoder, a different style of optical pickup than the OEM. This style pickup has proven to be very reliable and stable through extreme rpm and conditions. The rotor is bolted to a drive assembly that is indexed to the shaft and is stabilized through the use of a large ball bearing assembly.
Once installed, you have the ability to adjust the ignition timing – the only distributor that offers timing adjustability! An adjustment screw allows the timing to be tweaked up to +/-5°. The distributor is equipped with a fresh air vent and has an extra thick mounting surface for the cap to eliminate leaks.
The distributor is supplied complete with our heavy duty LT-1 Cap, Rotor and the components required for installation.
Pro-Billet LT-1 Distributor
’94-’96 Late Model PN 83811
’92-’94 Early Model, supplied with fresh air hoses PN 8381
Originally Posted by shoebox
If they don't use their own cap and rotor on their own opti, that would be pretty sad.
calling MSD...
calling MSD...
I was trying to say they might have made a different cap/rotor for the msd opti.
Originally Posted by Injuneer
Ignore him Rob.... appears he just likes to nit pick and take shots at people.
I just installed mine and started it up today. Didn't get to run it very long, cause I now have a huge hole in my header where the EGR pipe used to be.
Only things I noticed were that the cap didn't line up perfectly with the opti, had to kind of play with the screws to get it right. Second thing was that my stock hose that goes to the air intake was much too small for the connection to the opti. Probably gonna have to get a new hose or an adapter of some kind. I'll let y'all know more after a test drive...
