MSD Opti worth the money??
Old Mar 6, 2007 | 05:18 PM
  #31
SweetZRag's Avatar
Referencing Injuner's description and Shoebox's picture, the MSD instructions tell you to pull the hose off that goes to the EGR control valve and insert the T between the fitting on the manifold and the elbow. No cutting of the exisitng vacuum line necessary.
Originally Posted by Injuneer
The holes on the drivers side of the intake manifold are the same for all years. In the 93/94 cars, the lower/rear port is used for the PCV valve vacuum, connected by a short U-shaped hose. In the 95-97 cars, the vacuum for the PCV valve is run from a small port on the front of the manifold, under the throttle body. That frees up the lower/rear port on the side of the manifold for the Opti vent vacuum line. The port under the throttle body is there on the 94's as well, but it has a pipe plug in it. (Don't know if they had it on the 93's).
95-97 from Shoebox:
http://shbox.com/1/opti_vacuum_conn.jpg
Old Mar 6, 2007 | 06:36 PM
  #32
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Well I went through 5 GM opti's in 5 years on my car and have been running the MSD with no problems yet. I couldn't get my car tuned right away and the option it has to add or take away timing on it is bad ***.
Old Mar 6, 2007 | 06:46 PM
  #33
Fast_Toys's Avatar
We've been selling the Dynaspark version for a while and no complaints. It is a quality piece:
http://fasttoys.net/shop/product_inf...oducts_id=1253
Old Mar 6, 2007 | 07:31 PM
  #34
97ramairta's Avatar
i just bought a complete MSD ignition system from summit. the sad thing about it was after i ordered it i was taking things off to get to the opti and right down by the opti in the vaccum line there was a hole burnt in the line....causing my opti problem. now that just sucks
Old Mar 7, 2007 | 08:36 AM
  #35
SweetZRag's Avatar
Will this part be avaialble for the 93-94 LT1? The description doesn't list it. Also, it is $90 more than the MSD which does support the 93-04 and adds the venting option. Not complaining, just noting the differences for anyone comparing.
Jeff
Old Mar 7, 2007 | 09:42 AM
  #36
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I'm pretty sure that Dynaspark makes an Opti for the 93-94's. For six hundred bucks it should come with dancing girls.
Old Mar 7, 2007 | 10:27 AM
  #37
Fast_Toys's Avatar
Yes they have a 93-94 version as well shown in our catalog.
http://fasttoys.net/shop/product_inf...oducts_id=1252
Old Mar 7, 2007 | 11:30 AM
  #38
Jeff
The Dynaspark would appear to be a much more sturdy unit, billet case, upgraded bearing, etc. The MSD is closer to the stocker. I don't think I've ever seen anyone have a problem with the Dynaspark, but we've already had posts here about problems with the MSD.
Old Mar 7, 2007 | 11:40 AM
  #39
Fast_Toys's Avatar
Dynaspark
Agreed. We have never had any of our customers complain about the dynasparks. They have been around for quite a while too
Old Mar 8, 2007 | 07:03 PM
  #40
f1camaro's Avatar
I have a dynaspark,and so far so good.I got mine through fast toys also,great customer service.
Old Mar 8, 2007 | 07:41 PM
  #41
custom95's Avatar
I've been looking around for a new 94 opti as well, and here's what I've found: ac delco is $400-450, msd is about $500 or a little more, dynaspark is $600, also have heard good and bad about delco and msd but have not heard hardly any bad things about the dynaspark. For me, it makes sense to spend another 100 bucks to not have to replace it again in the near future.
Old Mar 8, 2007 | 07:51 PM
  #42
BTC's Avatar
BTC
Doesn't the MSD have a billet case and upgraded bearing? If they're comparable pieces, the MSD can be had for quite a bit less than the Dynaspark.
Old Mar 8, 2007 | 07:53 PM
  #43
BTC's Avatar
BTC
There is a thread called Opti #5 with reported dynaspark failures.
Old Mar 8, 2007 | 08:58 PM
  #44
custom95's Avatar
Thank you, I haven't bought yet so I definetly check it out.
Old Mar 9, 2007 | 07:40 AM
  #45
SweetZRag's Avatar
Doesn't the MSD have a billet case and upgraded bearing? If their comparable pieces, the MSD can be had for quite a bit less than the Dynaspark.
The MSD has a billet case but I am not sure about the bearing. I pulled my motor last week for a complete rebuild and I will be opening up my MSD (it has about 11,000 miles on it) to see how it is holding up. I will post what I find for anyone who is interested.
