MSD opti/opti problems??
Old Jun 15, 2008 | 08:14 PM
  #31
popstoy's Avatar
nobody mentions checking coil pink wire for corrosion into the plug if there is a problem car wont crank with no start the other wire will crank with no start happend to me move wire one way runs fine move the other way wont start.
Old Jul 8, 2008 | 09:21 AM
  #32
rickreeves1's Avatar
msd opti
Originally Posted by z28_4life
I just submitted an email to msd tech about the issue regarding the catostrophic failures on their opti's. I will be sure to let you all know their response to these clames. My problem is I've only put roughly 20 miles on my $500 opti that I purchased from them 2 years ago and the fact that their is only a 1 year warrenty on the product is outragous! There should have been some sort of recall on the product due to the vast majority of failures on their opti.
Any word back from them? Has MSD addressed any of these issues with their latest opti's?
I'm at 110k on the stock opti, still running strong. I was considering an MSD with a cam swap but may go with a stock one from thepartsladi. For those who have gone through a few opti's.. Is the MSD cap and rotor worth doing?
Old Jul 9, 2008 | 08:21 PM
  #33
z275plus's Avatar
I had the MSD Cap & Rotor once. The rotor grounded it's way into the cap and left me stranded.
Went back with a gm vented and has not had any problems since.
Will never use MSD again.
Old Aug 14, 2008 | 02:54 PM
  #34
z28_4life's Avatar
No, they never responded to my message. My car has since started dying after it warms up and goes into closed loop. My first guess would be the beautiful msd OPTI!!!! bwaa!!! Me venting. Anyways, I have a log of it if anyone could take a look at it to confirm opti that would be great. I have to let the car cool down for a couple hours and then it fires right back up until it warms up again, repeats process.
Old Aug 18, 2008 | 06:37 PM
  #35
z275plus's Avatar
GM all the way.
Old Sep 17, 2008 | 12:40 AM
  #36
z28_4life's Avatar
Any new reports of the wonderful MSD opti?
Old Sep 17, 2008 | 02:01 AM
  #37
2manyToyz's Avatar
check your wires before the plug connector
on mine three were frayed and making contact
have MSD and so far so good, but I am bracing
myself for the big one
Old Sep 19, 2008 | 12:52 PM
  #38
hosspwr94's Avatar
I had an MSD cap and rotor on a rebuilt back half... 15 miles and the car died. the whole opti was trashed include my rebuilt back half...
I sent the MSD back under warranty and replaced the back half under warranty.
The problem was the rotor screws back out. If you use the screws that msd sends with the kit they are little allen head machine screws that you cant get very tight. The second time around I used the screws that came off the stock unit and put some loctite blue (High strength stuff!) on them as well and can get them much tighter to hold the rotor. Hopefully when I get the car going again I won't have the problem like the first time.
Old Sep 19, 2008 | 03:54 PM
  #39
z28_4life's Avatar
Some of my concerns are: 1) Will the msd opti be re-usable if the rotor screws walked themself out. 2) Will msd cover this (probably not since my waranty is up) 3) Will simply replacing the cap/rotor ($150) do the trick? Along with new rotor screws and red locktight of course! Again, 10 miles on mine.
Old Sep 19, 2008 | 04:52 PM
  #40
96' Formula WS6's Avatar
1: Yes, just not the cap and rotor
2: I highly doubt it
3: Probably
RUENUF
May 25, 2016 08:10 PM
mr28
Apr 20, 2016 05:44 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
