msd opti and fuel
Old May 3, 2010 | 12:52 AM
  #16
RamAir95TA's Avatar
Originally Posted by bobhorn15
i asked nothing about lock tite. i told u my wires arent swapped. u didnt help that shop sucks i dont go back there
Maybe you should drill holes in your optispark to help it vent better, considering that's your solution for everything, even a good exhaust tone!
Old May 3, 2010 | 01:13 AM
  #17
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
Wow I remember when I had my first beer and posted on a forum...
Old May 3, 2010 | 01:53 AM
  #18
19camaro71's Avatar
in case op is still reading...
these guys are life-savers when it comes to advice on cars ... but some things you still have to figure out the hard way.
the reason the MSD opti is bashed is because it costs so much, for something you have to basically rebuild before installing. i know this because i have one. the loc-tite is a recommendation to keep the rotor from coming off while the car is running and destroying your $500 investment, similar to how mine almost did. there is little if anything to gain by an aftermarket opti and had i listened to the recommendations/known a little more at the time, i'd have a stock piece under the hood and $500 to invest somewhere else.
best of luck you finding someone to tell you what you want to hear!
Old May 3, 2010 | 01:58 AM
  #19
19camaro71's Avatar
by the way that motor in your picture isnt in a car. nerd
also... 200cc heads. not a 200cc motor.
Old May 3, 2010 | 05:26 AM
  #20
Correct.... you did not ask about lock tite because you apparently are not aware that the MSD Opti has a problem with the rotor screws coming loose. WHEN THEY COME LOOSE, YOUR ENGINE WILL NOT RUN AS WELL.
Now you tell us that the shop that did your Opti install "sucks" and you won't go back there. But they are the ones who might have failed to loc-tite the screws, failed to somehow set the adjustable tmiing correctly, and may have mis-indexed the splined drive shaft - ALL OF WHICH CAN CAUSE THE PROBLEMS YOU ARE HAVING. And the fact that they "suck" simply confirms that their incompetence may have been reflected in the way they installed the MSD Opti.
Well.... I can see this thread is going nowhere. I guess his philosophy is "shoot the messenger".
Good luck on "another forum".
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
