MSD Digital 6 plus box (for nitrous)
Old May 25, 2006 | 10:09 PM
plan Z's Avatar
alright i'm tired of having my pcm tuned only for nitrous. i want to tune it for the motor and be able to have a separate control to pull timing only while spraying. I keep on seeing that the Digital 6 plus box is for nitrous applications. My question is, is there a wire that you hook up so that it pulls the timing only when the wire is activated (by 12v or by grounding it)? I would like to be able to activate it either when i turn on my main activation switch, or when i am actually pressing the button to activate my solenoids. So will this box do this? If not any other suggestions
Old May 25, 2006 | 10:13 PM
Moshbmx1's Avatar
Re: MSD Digital 6 plus box (for nitrous)
Mallory 685 box
Old May 26, 2006 | 01:26 AM
2fast97z's Avatar
yes there is a red wire that comes out that when 12 volts goes to it..it activates pulling timing...i just hooked it up to my switch power so when my wot switch hit it pulled my timing
Old May 26, 2006 | 05:34 AM
2000GTP's Avatar
Originally Posted by Moshbmx1
Mallory 685 box
Thats what I'm using also. Plus, its a little cheaper then the MSD stuff.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Don 97 SS
Jul 11, 2005 08:50 AM
