MSD Digital 6 plus box (for nitrous)
alright i'm tired of having my pcm tuned only for nitrous. i want to tune it for the motor and be able to have a separate control to pull timing only while spraying. I keep on seeing that the Digital 6 plus box is for nitrous applications. My question is, is there a wire that you hook up so that it pulls the timing only when the wire is activated (by 12v or by grounding it)? I would like to be able to activate it either when i turn on my main activation switch, or when i am actually pressing the button to activate my solenoids. So will this box do this? If not any other suggestions
Re: MSD Digital 6 plus box (for nitrous)
yes there is a red wire that comes out that when 12 volts goes to it..it activates pulling timing...i just hooked it up to my switch power so when my wot switch hit it pulled my timing
