motor mounts mabye?
Old Dec 2, 2008 | 09:19 AM
firstlast's Avatar
motor mounts mabye?
ive been getting a vibration from my engine when im above 3k could it be my motor mounts?
Old Dec 2, 2008 | 11:00 AM
seawolf06's Avatar
Does it do it both in and out of gear?
Old Dec 2, 2008 | 07:08 PM
firstlast's Avatar
it is more in gear than out. i can rev it in neutral and it will vibrate but it is much more defined when under a load in gear
Old Dec 3, 2008 | 05:23 AM
Guest47904's Avatar
Guest
Look at 2 things. See if your tranny mount is broken like everyone else's stock unit and see if any weights came off the drive shaft.
Have someone look at the engine while you let the clutch out slowly with the E brake on. See how far the engine lifts on one side. Usually the bad tranny mount will break the motor mounts.
Old Dec 3, 2008 | 07:26 AM
firstlast's Avatar
i already have a vibeshaft when im above like 90 or so. thanks ill check the tranny mount today, but how can i tell if its broke or not?
Old Dec 3, 2008 | 07:44 AM
seawolf06's Avatar
You can try to jack up on the tranny to see if it moves. The other way is to drop the crossmember to get to the mount.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
