Preload on LS7 lifters
Old Nov 29, 2008 | 08:43 PM
David94TA's Avatar
I'm replacing my lifters with the LS7 version. What do you guys like for preload on these?
Old Nov 29, 2008 | 09:56 PM
94zgreenmachine's Avatar
As loose as possible. I went a little past 1/8th to 1/4 turn past zero.
Old Dec 1, 2008 | 11:16 AM
David94TA's Avatar
OK, thanks.
Old Dec 1, 2008 | 01:13 PM
wrd1972's Avatar
I went 1/4 TPZL.
Old Dec 1, 2008 | 07:47 PM
MachinistOne's Avatar
Why?
Old Dec 2, 2008 | 08:38 AM
95Blackhawk's Avatar
I went 1/6th turn past zero lash.
Old Dec 2, 2008 | 12:07 PM
wrd1972's Avatar
This is the way that I understand it.
The theory of running lifter preload as loose as possible is to minimize any loss of lift in the event that the roller on the lifter breaks free from the cam lobe surface as a result of float or bounce.
Since the lifter piston has more travel in the lifter body with 1 TPZL compared to less travel with 1/4 TPZL, the loss of lift is greater with more preload since it would have to pump up more to regain control of the valve. This is why some say to run the least amount of lifter preload possible to resolve a minor valve float problem.
If the roller rides perfectly on the cam lobe and NEVER breaks free from the lobe surface, then it would not make a bit of difference if it were 1/4 TPZL or 1 TPZL.
I fear running any less than 1/4 TPZL because if you run zero lash or any negative number of preload, then the retainer clip in the lifter body will be taking a beating which could result in carnage.
Again this is the way I understand it. Maybe I am smoking crack.
Old Dec 2, 2008 | 09:36 PM
I heard that myself and went to a professional engine builder and asked about this. He thought I was crazy. He said in certain classes where they have to run hydraulic lifters, they will even run up to 0.006 lash in some cases.
Sounds extreme to me but he has built more motors than me.
Old Dec 3, 2008 | 02:52 PM
wrd1972's Avatar
If this engine builder thinks it crazy, that hammering on the retainer clip by the lifter piston under race conditions wont result in carnage. I would consult a different engine builder.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Aug 24, 2015 06:41 AM
mrwz28
Jul 8, 2015 09:11 PM
