motor mounts mabye?
Look at 2 things. See if your tranny mount is broken like everyone else's stock unit and see if any weights came off the drive shaft.
Have someone look at the engine while you let the clutch out slowly with the E brake on. See how far the engine lifts on one side. Usually the bad tranny mount will break the motor mounts.
