Motor Mounts?
Old Feb 24, 2010 | 10:33 AM
NewbieWar's Avatar
Motor Mounts?
I really dont know much about motor mounts but after reading some stuff concerning installing my tubular K-Member, people recommend replacing them while your there, since they aren't terribly expensive. (151k miles)
so that being said, car is a daily driver/road course car.
installing UMI RR k-member,
where and what kind of motor mounts should i get?
Old Feb 24, 2010 | 11:16 AM
Z28SORR's Avatar
Stock mounts are perfectly fine, IMO, or if your a performance nut you can upgrade to "Poly". Chev., Jegs, Summit, JC Whitney, etc., etc, etc.
Old Feb 24, 2010 | 04:16 PM
Stock mounts will be fine.
Old Feb 24, 2010 | 09:03 PM
69z-28's Avatar
i went with prothane mounts, they're under 100 bucks IIRC and they use the factory clamshells. definitely a good idea to replace them when doing a k member
Old Feb 25, 2010 | 03:24 PM
gillta95's Avatar
I used prothane but remember you only need one side using that k-member.
Old Feb 26, 2010 | 01:34 AM
19camaro71's Avatar
I'm using the prothane as well with the same k-member. Very happy with them, but stockers would have been just fine.
Old Feb 26, 2010 | 01:35 AM
NewbieWar's Avatar
whats the difference between stock and prothane? and where does one pick up stock ones?
Old Feb 26, 2010 | 01:38 AM
19camaro71's Avatar
you can get stock ones at any parts store. the polyurethane ones are simply that, polyurethane instead of hard rubber. same duty, but they don't "give" as much as stock ones do. therefore you might feel more of the engine through the steering wheel. not a huge difference, but why not upgrade while you are under there.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
