motor mounts
Old Jul 13, 2005 | 12:56 PM
1crazylt1's Avatar
motor mounts
does anyone have pics on how to change the motor mounts? is it easy or does it take awhile n alot of work? let me kno
Old Jul 13, 2005 | 03:21 PM
Compstall's Avatar
Re: motor mounts
I've got a set sitting on my workbench. I'll take some pics as I go and let you know how it all went.
Old Jul 13, 2005 | 03:33 PM
1crazylt1's Avatar
Re: motor mounts
ok thanks
Old Jul 13, 2005 | 03:34 PM
RedRyder518's Avatar
Re: motor mounts
I changed my motormounts probably a month ago. Just a hint, if you are going to be doing headers soon, then do them at the same time! It seems to be pretty straight forward. My problem was when I tried to jack up the motor, my y-pipe would hit against my body so I could only get the motor up like an inch...not enough. I had to unbolt that all so I could get it to come up a good 3 inches or so. Remember to unbolt the tranny mount too! On the drivers side, I had to unbolt my steering linkage. I just could not get enough room to get it out with that in the way. Its not hard to do but kind of a pain. Do you plan on going with ES poly mounts? If so, they are awesome. My old rubber ones were so distorted it wasn't even funny. My header collectors were vibrating against my k-member and it was very annoying. Well good luck with it!
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
