most beneficial bolt on?
how hard is header install on lt1? motor is deep in their, i want heads/cam but aint got the $ right now
it has a stock CAI right? no need changin that, do u see any diff. if u un hook the hot coolant running thruogh the throttle body ?
header install is a b****, but well worth the trouble-get some friends to help(small handed ones)-while you are there,change plugs and plug wires-I would go with Hooker LT's or AS&M.The AS&M are not full length,but do have 1 3/4 primarys but are a little pricey.
it has a stock CAI right? no need changin that, do u see any diff. if u un hook the hot coolant running through the throttle body ?
A CAI is not a bad thing to do either. You'd probably see the same difference installing a CAI as you would headers because the stock airbox/airfilter is just as much a restiction as the stock exhaust manifolds. Plus a CAI takes less than 30 minutes to install.
i have 93k miles...would be ok? 6 speed...would i run into problems with stock engine components with 100 shot ?
I have head of people spraying on engine with 150k plus and running some great times, then again i have seen people spray on a 56k engine and throw a rod.
Originally posted by Grease
Headers can be anything from a breeze to a pain in the butt to install, it all depends on which kind you get. The best bang for your buck headers are Hooker LTs.
Originally posted by DjArcadian
I can't quite tell if you're joking or not.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
