Moser 9", Leaking fluid out the breather tube
Old Jul 10, 2003 | 02:53 PM
OBE1 95Z28's Avatar
Question Moser 9", Leaking fluid out the breather tube
I'm leaking fluid out my breather tube. It's an 18" hose that I have tie-wrapped up above the rear. I've added a catch can to the line to "manage" the fluid. Does anybody else have this issue? The fitting in the rear is located right where the axle tube meets the pumpkin.
Old Jul 10, 2003 | 03:15 PM
TedH's Avatar
I have the Moser 12 bolt. It leaked through the tube when I filled the rear from the plug on the TA cover (it was too high so I put too much fluid in). After I drained it down to the level of the plug on the side of the pumpkin the problem went away. It did drip for a couple of days while any fluid in the tube was working its way out.
Old Jul 10, 2003 | 09:11 PM
OBE1 95Z28's Avatar
It's filled properly as I used the fill plug in the side of the housing. I changed the 1/8" ID breather hose to a 1/4" ID to see if that helps. I was hoping someone else has already solved this.
Old Jul 10, 2003 | 10:13 PM
TonyJ's Avatar
It must be a common problem. I noticed the oil recovery cans listed in Jegs say they work for diffs, as well...
PCLZ28
Dec 24, 2015 05:19 PM
jmadoll
May 27, 2015 07:13 PM
ddr698
Jan 9, 2015 10:05 AM
kev93z28
Aug 19, 2002 12:48 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
