Moroso oil pan. Will it leak wihout gasket maker ?
I just had a shortblock assembled and I noticed there was no gasket maker used on my oil pan gasket. Its a used pan with a new one piece blue gasket.
I already have the engine, tranny assembled and bolted to the k-member. Should I pull the pan and add gasket maker to the corners of the pan or will I be OK.
Is the used pan in good shape around the sealing surface? If its not true and flat, you might want to use a gasket sealant. Did the gasket manufacturer recommend sealant be used?
Magenta_Hearts
Mar 25, 2015 10:24 AM
CARiD
Jan 27, 2015 06:27 AM
