coolent fans
coolent fans
I need a little help please. my son was deployed and had his 1995 Z28 Camaro sent up to us. he will be comming home soon so he wanted me to get hs car ready.
when i let it run it gets hot and the fans wont kick on. i replaced the thermstat,fuse,and all 3 fan relays. and still the same. I also pulled the air pump relay and tried turning on the ac and they still didn't come on. any help would be great.
The fuses are for the signal voltage to the relays. There is also a fusible link in the main 12V power supply to the load side of the relays. The link attaches to the red plastic "+" box on the passenger side inner fender.
Look at Shoebox's wiring diagrams.
first off thank you all for the help. sorry for not getting back sooner but work calls sometimes. so i jumpered the 5 and 6 on the DLC and the fans came on.
so now i will try and break down the wiring and see what I can find.
If they come on when you jump the DLC, then the wiring and relays are all good. As described on my website, a scanner will allow you to read the temperature the PCM sees. It will also tell you if the fans are commanded on at the programmed temperature.
Formula Steve
Sep 19, 2023 08:31 AM
