more cam help PLEASE
Old Dec 13, 2004 | 02:34 PM
  #31
dmoor88's Avatar
Re: more cam help PLEASE
if you're starting to fall off ~6000-6100R RPM's, wouldnt you want to shift closer to 6000, 6100 at most?
Old Dec 13, 2004 | 03:53 PM
  #32
97 6SPEED Z's Avatar
Dmoor88, actually no! This can get real difficult to explain but let me try a simple way to explain this to you? Say your car made the following HP numbers at RPM and had say, a 1,500 RPM "step" between shifts:
Before shifting the car makes
350 HP @ 6,000 RPM (This is the peak).
348 HP @ 6,100 RPM (Down 2 HP from peak)
345 HP @ 6,200 RPM (Down 5 HP from peak)
After shifting from:
6,000 RPM (making 350 HP) new RPM is 4,500 RPM and car makes 260 HP @ 4,500 RPM
6,100 RPM (making 348 HP) new RPM is 4,600 RPM and car makes 264 HP @ 4,600 RPM
6,200 RPM (making (only???) 345 HP (i.e. down 5 from "peak") new RPM is 4,700 RPM and car makes 270 HP @ 4,700 RPM
Under these conditions it would actually be better to shift at 6,200 RPM and "ride down" the power curve after "peak" power, because you will gain more power after the shift, since the car will start from 4,700 RPM where it will be making 270 HP vs starting from say 4,500 RPM where the car is (only) making 260 HP! Do you "get" what I'm trying to explain???
Old Dec 13, 2004 | 05:03 PM
  #33
Z95m6's Avatar
I thought i've read on here that you want to shift 500rpm's past peak. I dunno if thats a good rule of thumb or not.
Old Dec 16, 2004 | 06:35 PM
  #34
camaroKid223's Avatar
well i tried Dave at combination motorsports and got no reply so I guess ill look elsewhere. Anyone know of any online places that carry the 847 for a good price?
Old Dec 16, 2004 | 06:37 PM
  #35
I take that back he just sent me an email and even apoligized for the hold up. very good man
Old Dec 16, 2004 | 06:44 PM
  #36
Heres what Dave recommended
TN230XL(230/236, .544/.555 on a 112 LSA) what do you guys think? That vs. the 847?
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
