Mass Air Conversion On 93' Lt1?
Old Dec 16, 2004 | 10:21 AM
Downshiftndrift's Avatar
I was wondering how hard this is. I heard you need a new ECU, but the 94+ ECU's wont match up to my transmission b/c it is that funky year in which that wierd trans was made. Its a mixture of the 700r4 and the 4l60e. Is there a way to do this w/o changing my ecu or w/o changing my transmission? Anything to help me out is much apreciated. I can't stand this speed density garbage.
Old Dec 16, 2004 | 10:49 AM
Alvin@pcmforless.com's Avatar
Re: Mass Air Conversion On 93' Lt1?
Why not?
Old Dec 16, 2004 | 03:29 PM
Zepher's Avatar
Your transmission is a 700R4, 93 was when they renamed it to the 4L60.
You will probably need to change the ECM and harness with a 94-95 PCM and harness and wire up a swtich to lock the converter up manually.
I personally think it would be too much of a pain to do this conversion on your car.
What problems are you having with the SD setup you have?
Old Dec 16, 2004 | 04:00 PM
bad93z's Avatar
I can see wanting to change because of ease of tuning, but I looked into it with my old car, and it just seemed like too much hassle.
Old Dec 16, 2004 | 04:36 PM
thanks guys
Old Dec 16, 2004 | 04:43 PM
Zepher's Avatar
The only difference between the 4l60 and the 4l60e is that the PCM does the shifting.
If you have the 93 ECM & your tranny is electronically shifted then you have a stand alone tranny PCM.
Old Dec 16, 2004 | 06:23 PM
Tuneing the 93's are cake now with all the emulation tools out.
Besides that, they are stronger cause they dont' have to deal with a MAF sensor upstream
Old Dec 16, 2004 | 06:57 PM
CamaroZBoy's Avatar
Speed Density 4 lyfe....dont convert to MAF
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
NHSZ28
Jul 25, 2002 07:58 PM
