modification help
modification help
i just bought another camaro 1995 z28 m6 the guy i bought it from he doesnt know what modifications the car has when i checked it out i noticed it has short shifter, intake, exhaust, and roll cages also the vavle covers where chasnged and shorter gears comparing to my other Z. he mentioned it may be camed but he is not sure. my question is "is there a way to find what kind mods the car has? any suggestion would be helpful
Re: modification help
when i was driving the car i noticed the oil pressure is different from my other camaro
this one after it warms up it idles 1k rpm and the oil pressure is about 50psi my other camaro was 20 psi same idle
my new z28 is 95 the other one is 94
i use mobile 1 synthatic 10w30
if i have a cam does that also raise the oil pressure
if have cams (not sure yet) it should be comp305 cuz the engine is not that aggressive but more faster than my 94 z28
Hmm, a car with a cage but might or might not have a cam? Curious...
If they had he engine apart perhaps they added a different bypass spring to the oil pump. I have the 'white' spring in mine and have 25 psi at a hot idle.
The sending unit could also be wrong. The one in my Silverado read 80psi at idle...until I replaced it lol
Could try to put a degree wheel on the crank...but that would require removing alot of stuff just to check the cam.
Could measure the lift tho without much effort and see if its much different than stock. Inspect valve spring size too to see if those changed... a cam swap would most definately warrant a change of valvesprings.. Although they may be stock type diameter, it be easy to tell if coils are the same thickness or double spring/beehive vs stock style.
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
