Cheap good timing set
Old Apr 21, 2012 | 12:15 AM
Cerridius's Avatar
Would this fit my spline drivin opti on my 94? This is the cheapest ive see so far.
Timing Kit/component/Timing Set (73126) | 1994 Chevrolet Camaro 8 Cylinders P 5.7L SFI OHV | AutoZone.com
Old Apr 21, 2012 | 06:01 AM
bw_hunter's Avatar
Re: Cheap good timing set
I'd really inspect the original closely and consider reusing it before using a cheap Chinese junk set.
Cheap is a seriously bad idea in a timing set.
If you're set on replacing the set, consider using a Cloyes set. they're a tier one supplier to GM and may have been the OEM manufacturer of the stocker. The part number I found was C-3228 but double check to be sure...
Cloyes manufacturers in the US...
Old Apr 21, 2012 | 06:36 AM
96capricemgr's Avatar
Why do you think you need to replace it?
Pretty much nobody breaks stock chains even on modified engines and then when guys replace them I think I have seen more replacements break than stockers. The stock one is meant to handle the load of the waterpump so it was pretty heavily built.
Old Apr 21, 2012 | 06:43 AM
Cerridius's Avatar
Oh, I'm just shopping around for possibly a timing set for my heads and cam swap. But seeing these are not many options for a timing set I thought I would share this. I'm not gomna replace gears and chain till I look at mine.
Old Apr 21, 2012 | 07:54 AM
If looking for an "upgrade" I might consider the Lunati set but I have no data to support it being an upgrade, otherwise stock/cloyes.
Old Apr 22, 2012 | 08:26 PM
CamDriver's Avatar
do any of you know a good chain that has the 3 keyways on the crank gear??? im looking and only found one so far but didnt know if i could get a better price than 280.00 in summit.. if you know of any thanks
Old Apr 23, 2012 | 12:26 AM
Cerridius's Avatar
I dont kno much about timing chains reall, sorry
Old Apr 23, 2012 | 01:48 AM
MachinistOne's Avatar
Just get a new chain($40) for your existing gears, the LT1 sets are a rip-off.
Again, just get a new chain, then use an offset bushing kit to degree your cam and save the $200
Old Apr 23, 2012 | 08:45 PM
CamDriver's Avatar
the reason i want the 3 keyway crank gear is because i want to degree in my cam
Old Apr 23, 2012 | 10:26 PM
You don't need to buy a $280 three keyway set to degree the cam, those things rarely fall into the right spot anyways. Most builders all use offset bushings on the camshaft like I said in the first post - those kits cost $20 and are easy to use, that's what I use even when I have a three keyway set in my hands, it's faster to swap the bushings than it is to pull a pressed on gear on and off.
Old Apr 24, 2012 | 07:09 PM
CamDriver's Avatar
i didnt see that thank you, can you explain a bit more about it to me!! i looked at the cam gear i dont see where i can put a offset bushing do i need to drill out a hole????? thanks for your help
Old Apr 24, 2012 | 07:28 PM
bw_hunter's Avatar
yes, you drill out the holes to accept the bushings. here's a link to how: http://www.jegs.com/InstallationInst...70-11991-1.pdf
Old Apr 24, 2012 | 07:32 PM
CamDriver's Avatar
thanks!!!!!
Old Apr 24, 2012 | 08:17 PM
I actually don't drill the hole all the way through like it says in those directions, I drill it from the back side just enough that the bushing will drop in and be below flush - this way it is captured and has no possible way of coming out the front side and you don't need to buy a lock plate.
Old Apr 24, 2012 | 08:34 PM
bw_hunter's Avatar
And that's why you talk to a machinist before drilling or cutting......
Great idea!
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
cmdeshon
Dec 12, 2014 10:51 PM
Snoman73
Nov 17, 2014 07:22 PM
