miss fire or some thing
Old Apr 18, 2011 | 08:51 PM
DTRJAR's Avatar
Ok so i just put new motor in its a 355 with a com cam 501, edelbrock air gap intake gmmp rods bee hive springs srp pistons here is what going on when i get in to the throttle it feels like its holding back like it has a miss i did put in a lt4 knock sensor could that make it do this or is it not getting enough gas or what thanks need help asap
Old Apr 18, 2011 | 08:55 PM
my1994z28's Avatar
Re: miss fire or some thing
Have you had it tuned yet?
Old Apr 18, 2011 | 09:24 PM
bobbyowsley's Avatar
Second the tune...also might be a crossed plug wire. Very easy to do and very easy to check.
Old Apr 18, 2011 | 09:27 PM
my1994z28's Avatar
Scan it for codes,check the fuel pressure,double check the plug wires,make sure they are on the correct terminal..Are you sure the valves are adjusted correctly?
Old Apr 18, 2011 | 09:46 PM
DTRJAR's Avatar
when we put the scanner on it wont read ....
what should the fuel pressure be set at .... ill check wires tomorrow
valves dont know lol .....
Old Apr 18, 2011 | 09:50 PM
my1994z28's Avatar
With the key on,engine off it should be 41-47 psi.
Old Apr 18, 2011 | 10:05 PM
DTRJAR's Avatar
even with the stuff done to car do you think i need to put it up a lil or any thing
Old Apr 19, 2011 | 01:45 PM
DTRJAR's Avatar
It was the O2 sensors we unplugged them and now it runs perfect thanks guys for the help
Old Apr 19, 2011 | 04:29 PM
What scanner did you use? A lot of people see the 16-pin OBD-II style ALDL connector, and assume they are reading an OBD-II PCM. But the 95 is an OBD-I PCM, and you need to use an OBD-I scanner, with the correct adapter plug, or use jumper wires, as Shoebox shows:
http://shbox.com/1/xraycable.jpg
Old Apr 19, 2011 | 06:40 PM
DTRJAR's Avatar
I was using a OBD2
Old Apr 19, 2011 | 10:54 PM
I was using a OBD2
That would explain why it didn't "read".
armedtrigger
Feb 24, 2015 08:30 PM
DetroitZ28
Feb 13, 2015 07:33 AM
nophix
Nov 30, 2014 10:26 PM
Hal Fisher
Sep 14, 2002 09:36 PM
