miss fire or some thing
Ok so i just put new motor in its a 355 with a com cam 501, edelbrock air gap intake gmmp rods bee hive springs srp pistons here is what going on when i get in to the throttle it feels like its holding back like it has a miss i did put in a lt4 knock sensor could that make it do this or is it not getting enough gas or what thanks need help asap
Re: miss fire or some thing
Scan it for codes,check the fuel pressure,double check the plug wires,make sure they are on the correct terminal..Are you sure the valves are adjusted correctly?
what should the fuel pressure be set at .... ill check wires tomorrow
valves dont know lol .....
http://shbox.com/1/xraycable.jpg
armedtrigger
Feb 24, 2015 08:30 PM
Hal Fisher
Sep 14, 2002 09:36 PM
