How much hp can improperly gapped plugs cost your engine?
Old Apr 19, 2011 | 02:27 AM
bkpliskin's Avatar
Hey guys,
Just wondering, how much hp can improperly gapped plugs cost your engine and can it this do any damage to your engine? Will this cause the engine to pull any timing?
Thanks,
Ben
Old Apr 19, 2011 | 10:09 AM
bw_hunter's Avatar
Re: How much hp can improperly gapped plugs cost your engine?
Originally Posted by bkpliskin
Hey guys,
Thanks,
Ben
It's impossible to know how much power this will cost you but probably not much. A larger gap is know to lead to rough idle and what feels like a miss but not detonation leading to any spark timng retard. I run a tighter gap than stock with no ill effects at all.
What gap are you talking about...
Old Apr 19, 2011 | 10:58 AM
green.Z's Avatar
I've only had experiences with the gap being too large, like about .100". On the LT1, it would miss pretty bad even just while cruising. On the LS1, it didn't seem to make that much difference. It was a case of the platinum "puck" on the AC Delco plugs falling off in both instances.
Old Apr 20, 2011 | 02:10 AM
MikeGyver's Avatar
How much power can be lost? I'd say between 0 and all of it.
Why do you ask? Are you saying your plugs are improperly gapped but you don't want to fix them? or are you thinking you're gaining something somewhere?
If so, a better might be question is how much power will be gain running by running an 'improperly' large spark plug gap? Probably none...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
