Misfiring.
Old May 6, 2008 | 10:23 PM
sandman63's Avatar
Misfiring.
Just did a header, water pump, opti, plugs an wires install. I probably drove the car about 100 miles already without any problems, an today i was out, an i hit the rev limiter once, an then a few mins after that it was mis firing...
I can put it in drive an it kinda shakes n stumbles. It starts goods, an idles kinda funny but hard to notice it.
Any idea what happended?
Old May 6, 2008 | 10:44 PM
Burned a wire on the headers?
Before you installed the Opti, did you check the rotor screws and lock-tight them? Was it a GM Opti, or some other brand?
Old May 6, 2008 | 11:44 PM
mrmint69's Avatar
Where the headers coated? Check to be sure the plugs aren't loose, the wires aren't burnt or loose and the water pump isn't leaking. With several thing all at once done it could be a couple of things.
Old May 6, 2008 | 11:47 PM
transam1577's Avatar
could also have a cracked plug like i did!!! just take your time and double check everything..
Old May 7, 2008 | 06:22 PM
sandman63's Avatar
Yes it was a GM opti. And no i did not check the screws? I did not know i was supposed too...
christiangirl
V6 Tech
Apr 15, 2010 05:41 PM
Gtpguy
Jun 2, 2008 04:09 PM
Texas_96_Z
Oct 1, 2006 11:55 AM
jgonzales
Jul 13, 2004 04:39 PM
john97z28
May 10, 2004 03:41 PM
