Is my opti dying?
Old Jun 2, 2008 | 12:51 PM
Gtpguy's Avatar
Is my opti dying?
Last week out of nowhere I get to a stop light and the car starts idling rough and low. About 600rpms. Feels like misfiring. I get home let it cool off and the see that the last plug on the passenger side is loose. Tighten 'er up and check the others ones as well. I don't drive it for a week. Friday I go for a drive and everything is fine until about 3 miles down the road. It starts happening again. Rough low idle and misfiring. So I turn around and drive home. Within a mile the car is fine again. So I go home and check all the wires again. Start it up and now it's backfiring, misfiring, and idling at 600rpms in my garage.
I did a LT header install over a month ago and haven't touched anything else since. Does this sound like a dying Opti or something else? What codes trip the SES light for a bad opti?
Old Jun 2, 2008 | 12:59 PM
slomarao's Avatar
After the LT's did the car drive like normal? Did the car behave screwy afterward?
Is there anyway you burnt a plug wire?
Just trying to rule out other outcomes before I would deem it an opti issue.
I would re check the plugs wires and the routing again. A number of other things could cause this.
Old Jun 2, 2008 | 03:26 PM
Gtpguy's Avatar
The car ran totally fine for 3-4 weeks with the LTs without a single problem. Up until a week ago. But the thing backfires and pops in idle. And for a little while it was intermittent.
Also, I forgot to mention that crusing around 70mph there is a slight stumble. Like I let off the gas but I didn't. It was doing that for about a year or so. Nothing major, I just went a little faster and the problem went away.
Old Jun 2, 2008 | 03:53 PM
user 647483's Avatar
Make sure the plug wires are not melting on the LTs
Old Jun 2, 2008 | 04:09 PM
reamo04's Avatar
sounds like a plug wire to me.
I would pull all your plugs and check those too, common mistake is people crack the insulator installing the headers. For like $12, wont hurt to change to some tr55's anyway
88IROC_Z
Jul 22, 2015 11:38 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
RUNMYTA
Jul 15, 2015 07:50 PM
asilomar244
Jul 12, 2015 05:53 AM
