Misfire codes, did I fry the ICM?
Old Jul 27, 2004 | 11:00 PM
Gos2Slo's Avatar
Angry Misfire codes, did I fry the ICM?
The last couple days the car has been running pretty rough, after a couple seconds at idle it starts to get choppy. Horrible (I mean, 4 banger horrible) acceleration and it damn near refuses to rev at all.
I got codes 0303, 0307 (misfires on those cylinders) and I got it home and tore into it a bit. I found that two wires bolted to the ICM stud had broken, one was a braided chassis() ground, the other was a small black wire. I reterminated both wires and put it back together, it was better for all of 30 seconds and then it started again.
Could I have fried the ICM by not having these wires connected for any period of time? I tried bypassing the MSD, no joy, fuel pressure is good so I am pretty sure it's spark. No other codes have shown up yet. It starts up and shuts off just fine.
Help! I have a new problem with this car every 3 weeks and I'm gonna lose it pretty soon. Any help or advice is MUCHO appreciated!
Old Jul 28, 2004 | 09:51 AM
Re: Misfire codes, did I fry the ICM?
If your misfires are limited to those two cylinders, and you aren't getting any codes for the ICM, I'd say you have a plug wire problem.... maybe cross-firing between those two wires.
Old Jul 28, 2004 | 11:29 AM
Gos2Slo's Avatar
Nope, I had a "Bank 1 lean" misfire code for a few minutes then it went away, but I thought my fuel solenoid for the nitrous kit was leaking again. I disconnected the fuel line to the nitrous plate and ran it again, started getting misfire codes. I checked the injector harness, battery terminals, and the ground wire, all are nice and snug.
At one point the car wouldn't start at all, I thought it might be the battery cables because there was no juice or spark ANYWHERE, so I picked up the battery and jiggled the cables, then it started right up. Maybe a broken battery cable is causing this? I have over 13.5 volts at cruise on the factory gauge.
Anybody know what the two wires grounded to the ICM were?
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Hannibal
Sep 10, 2002 04:25 PM
91Bird305
Aug 5, 2002 01:39 PM
camaro_ss01
Jun 25, 2002 09:38 PM
camaro_ss01
Jun 25, 2002 09:35 PM
