Help with my slowmaro?
Old Jul 26, 2004 | 08:41 AM
M-MAN's Avatar
I have a problem with my slowmaro that I just cant figure out. After about 20 min. of driver the car starts to misfire and wants to cut out. If I step on the gas it cut off and starts jump around the rpms. Sprak plug, wires, coil, and module are new. Any ideas what it could be?
Old Jul 26, 2004 | 12:46 PM
slopokrodrigez's Avatar
Re: Help with my slowmaro?
Sounds like Opti since the PCM uses the feedback signal from it to drive the output to the tach.
Old Jul 26, 2004 | 12:55 PM
M-MAN's Avatar
thanks, i was thinking it was the opti. 217K is enough time of a replacement
Old Jul 26, 2004 | 01:22 PM
z28marine's Avatar
could be the fuel pump...do a quick pressure check on it
Old Jul 26, 2004 | 04:06 PM
217,000 miles on one opti. Holy hole in the donut Batman, that must be some kind of record. I don't think your fuel pump would make the rpms jump higher than actual. That's why I think its the opti.
Old Jul 28, 2004 | 11:55 AM
M-MAN's Avatar
i WAS the fuel pump. Got 2 psi on start up and never got above 25 psi.
FireChicken1995
West South Central
Sep 3, 2008 06:03 PM
FireChicken1995
May 27, 2008 12:33 AM
FireChicken1995
West South Central
May 26, 2008 08:32 PM
FireChicken1995
Apr 24, 2008 11:02 AM
M-MAN
Jan 3, 2007 01:01 PM
