min clearance between oil an and steering rack?
So.......is there a minimum clearance between the oil pan and the steering rack?
I have a Canton oil pan installed, and it was hitting my steering rack.
I bought 6 thick washers and put them underneath the motor mounts, and now it fits.......but how much room is needed for the engine to move around during driving? I dont want to wear a hole through the pan accidently........
Also, is it bad to hammer on the oil pan alittle? "massage" it so to speak?
I did mine with oil in it and everything too......
I took a 2x4 and put it where the rack goes(took the rack off) and hit it across....I had a rag on the 2x4 and you can't even tell. Just do a little at a time.
You should be fine with the washers....it changed the drive angle a very little but with regular motor mounts It won't be any problem.
Victor Lamb
Aug 26, 2017 02:52 PM
mspennyhughes
Mar 1, 2015 03:50 PM
