slipping trans???
Old Dec 22, 2007 | 05:26 PM
northdakota93z28's Avatar
slipping trans???
is what i thought was happening but i took it to my tranny guy and he says it is starving for fuel, i changed the fuel filter and it still does the same. At the top of third it stumbles. I will do a fuel pressure test and if that is good, I will go from there. Any help would be great.
Old Dec 22, 2007 | 11:46 PM
mrmint69's Avatar
You have said exactly what i would have said. Lets hear how the pressure test turns out. Always take fuel advice from your tranny guy.
Old Jan 1, 2008 | 02:28 PM
fuel pressure was good, at wot in 3rd when it stumbles it is at 43psi, so now i want to test the injectors because another guy had the same problem i had and he changed alot of stuff and it turnout to be his injectors, what do you guys think any help would be great.....
Old Jan 1, 2008 | 02:53 PM
mrmint69's Avatar
What injectors (size & brand) are you currently running?
Old Jan 1, 2008 | 03:11 PM
stock and i am going to buy new ones did some searches and found out that is prob. how much for stock injectors??
Old Jan 2, 2008 | 02:36 PM
mrmint69's Avatar
Ebay has used ones for under $50. What did you find that told you it was the injectors?
Campbellb48
Jul 5, 2015 06:31 PM
kmk7110
Jun 20, 2015 05:53 PM
blkWidow
Apr 21, 2015 01:56 PM
jackpawt883
Feb 26, 2015 09:04 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
