Medium pitched "whine"
Old Jan 2, 2004 | 04:35 PM
fade94's Avatar
It does it when I am getting into it pretty good. Usually around the 5-5500 rpm range. Any ideas?
Old Jan 2, 2004 | 08:24 PM
BigEvil's Avatar
What does it?
Old Jan 2, 2004 | 09:35 PM
hozb817's Avatar
If you have an aftermarket gear ratio like 3.73 or 4.10's then the noise is normal, if not then I'm not sure. Hope it helps!
ChickenScreamer94's Avatar
Can you go into further detail? I am assuming it is from under hood? My car makes a whine, kinda like a supercharger at that rpm. I think it is just the sounds it is suppose to make at 5K
Old Jan 2, 2004 | 09:53 PM
fade94's Avatar
Yes, from under the hood. My son thinks it sounds cool. Does it at higher RPM. Oh well, other than that, the motor is rockin'
Will be doing a rebuild on it shortly. Trying to decide between a high HP/compression 383, or low HP/compression 350 and supercharge it.
Old Jan 2, 2004 | 10:00 PM
Cmr0z28's Avatar
Ditto
Old Jan 3, 2004 | 10:27 AM
hozb817's Avatar
usually if its your gear ratio the noise would come from the rear, your back seat area. It does sound pretty mean!!
93 RedBird
Nov 15, 2015 08:24 AM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 2, 2015 10:29 AM
Rob(94Hawk#319)
Advanced Tech
Jul 28, 2002 12:05 AM
KASR_Z28
N2O Tech
14
Jun 26, 2002 09:08 AM
