mechanical speedo w/ 4L60e
Old May 7, 2004 | 11:41 PM
kevmor99's Avatar
Question mechanical speedo w/ 4L60e
Anyone use a mechanical speedo and also the VSS sensor w/ a 4L60e? I'm looking at relaoting the reluctor ring on the output shaft and installing a new VSS, then installing the mechanical speedo in the original opening.
Old May 8, 2004 | 10:17 AM
12SCNDZ's Avatar
You can, but the computer needs a digital speed reading to tell the transmission when to shift.
Frank
Old May 8, 2004 | 11:54 AM
IrocSS85's Avatar
what are you trying to accomplish? are you putting a 4l60E in an older car? why go w/mech. speedo? your PCM DOES NEED the vss signal to know when to shift the trans.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
4586
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
