100k mile stock LT1 rods and crank - worth reconditioning and reusing?
hey guys
just wondering if stock 100k mile LT1 rods are worth reconditioning and reusing for a budget 355 rebuild?
what about stock 100k mile crank?
estimating approximately 6500 rpm shifts (maybe a little less) on a new setup with AI heads and AI custom cam....
thanks!
thanks!
Id actually tend to agree with him unless you are on a very tight budget some eagle SIR rids are pretty cheap, but you might get away with a rod bolt upgrade, 80 bucks if you want the crank, that is most of the cost since it was the only part I would re-use, but your shipping will be alot less, i gotta go to work, Ill be on tomarrow. bye...
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
1LEThumper
Jul 14, 2003 12:45 PM
