Measuring Knock sensor resistance?
Old Dec 23, 2006 | 02:01 PM
2QUIK6's Avatar
Trying to measure the resistance of my knock sensor and I'm a little confused with the readings I was getting, they seem to be all over the place.
I have the ohmmeter dial set on "20K".
Measuring with the probe on the center post of the sensor and the other probe on the ground wire just above the sensor, the reading is 3.87...so it that only 3870 ohnm?? As I move the probe around on the ground the reading goes from anywhere between 3.8 and 189.0
So I'm guessing the least resistance while sliding the probe around on the ground wire connection above the sensor is the reading I want. and if its 3.8k then it WAY LOW as a good sensor should be between 93k - 107k right?
Old Dec 23, 2006 | 04:08 PM
Measure the resistance of the sensor, itself, from the center terminal of the sensor, to the metal side of the sensor or engine block ground, not to the ground wire of the harness.
Tell us what year this car you are testing is.
http://shbox.com/1/4th_gen_tech2.html#knock_sensor
Old Dec 23, 2006 | 06:09 PM
2QUIK6's Avatar
Thanks sb! I did measure the resistance on the metal part of the KS itself and it was also 3.8k. I see on your site, 3300-4500 is good for OBD1. Sorry, this was on my 95 TA, so it is within range! The values I had were for OBD2.
Many thanks!
99z28 carguy
May 26, 2015 11:35 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
