Me vs. LS1
Old Oct 10, 2009 | 01:16 AM
  #16
SmokeyBlaZe's Avatar
also I've got 2.02/ 1.6 valves and about 11:1 compression
Old Oct 10, 2009 | 01:20 AM
  #17
Originally Posted by The Untouchable
definatly a plan , my brother has a 94 Z vert with p&p stock heads with2.00 /1.94 valves ,valves springs hardend push rods, stock rockers, ported intake ,isky custom grind .610 lift,bbk shortys ,stock y pipe with stock cats, 3in catback magnaflow, stock tb ,stock inj. stock stall with fully built 4l60e, 3.73's, CAI, and bbk under drive pulleys, and custom tuned it on the dyno and he just layed down 429rwhp 2 days ago at Wyotech in PA
and im pretty sure with a stall , 58mm tb ,42lb inj and retuning it he could lay down almost 450 to 460 rwhp
just something to think about , he can ebliterate the tires at 40 mph running 255/50zr16's like it is now,
im waiting for him to send me his 52mm tb comp pro magnum rr's and some other stuff
Those are some very impressive numbers, Whats he redlining at?
Old Oct 10, 2009 | 01:22 AM
  #18
When you say bbk underdrive pulleys , do you mean this?
http://autopartsway.amazonwebstore.c...B000CIRA0S.htm
And would you be able to use the same belt?
Old Oct 10, 2009 | 01:29 AM
  #19
The Untouchable's Avatar
i mean if your tuning has your trans shifting above 5800 i wouldnt go past 6k if u are manual shifting ur auto,
he is redlining at 6500 rpm
yes that is the bbk kit but is should come with a shorter belt i can get the belt part # u will need if u want
Old Oct 10, 2009 | 01:31 AM
  #20
dayco 59-1/2 in or 60" belt
just got off the phone with my brother and he just told me that on the dyno he was still makin more power after 6500
Old Oct 10, 2009 | 01:36 AM
  #21
so which one is it? lol , I'm still running a/c by the way
Old Oct 10, 2009 | 02:04 AM
  #22
chit hes not running A/C , bbk should have the info on there site lol
Old Oct 10, 2009 | 03:37 AM
  #23
Whats the bottom end look like? stock? how many miles are on it?
Old Oct 10, 2009 | 03:41 AM
  #24
94ltz's Avatar
Not really sure why your shifting at 5800, i know people say these engine aren't made for the high RPM but thats also with the stock set up, with the CC306 take that thing up higher like 6200 and shift.. You have the heads to flow so why not put them to use, and get those 2.73 out of that rear, with 3.73 and a 3,000+ stall that thing will move off the line but you will need a good tire and some suspension work to get her to hook.. If your going after a LS1 like that your going to have to leave with him and take the RPM like they do or else they will eat you alive cause while your shifting their pulling away..
Old Oct 10, 2009 | 03:56 AM
  #25
Good Advice
Old Oct 10, 2009 | 12:23 PM
  #26
he has 126k on stock bottom end , the reason i say not to go much above 6100 rpm if u have stock bottom end and some miles on it , yes he was makin power beyond 6600 rpm but he didnt wanna be on barrowed time at that rpm, but also the bottom end is in very good condition.
Old Oct 10, 2009 | 12:38 PM
  #27
Hal Fisher's Avatar
Get at least a 3.23 axle from a junkyard. I've been in a 2.73 and they feel weird. Much more highway geared and can't take off worth a crap.
Hal
Old Oct 10, 2009 | 02:00 PM
  #28
Should I try to find a whole rear end or just the gear ring & pinion? What series carrier do I have?
Old Oct 10, 2009 | 03:21 PM
  #29
how do u have 2.43's i thought z28's came with 3.42's stock ,
The gears in the "base" V8's, with an A4 tranny were 2.73's (RPO GU2). You got 3.23's if you opted for the "performance rear axle" package (GU5). 3.42's (GU6) were only used in the M6 cars starting on 94 model year. In 93, even the M6's had either 2.73 or 3.23 gears.
http://www.ws6.com/faq/4_3.htm#ch4_3a
2.73's use a 2-series carrier. But you can buy 3.73's for a 2-series..... they are just thicker than the 3.73's for a 3-series.
Old Oct 10, 2009 | 04:31 PM
  #30
i would find a whole rear , they can be had for bout 150 to 200
