max cam lift for lt1
Old Feb 11, 2004 | 12:36 AM
ftransam1's Avatar
Just curious what the maximun lift I could give my LT1? Got a new cam but am afraid to go with 1.6 RR because the lift will exceed .600 Anyone know how high I can go or what the highest safest lift would be?
Old Feb 11, 2004 | 12:37 AM
Brandon 95 Z28's Avatar
Whats your motor setup, and you will need to make sure you have very good valvesprings for above .600
Old Feb 11, 2004 | 12:38 AM
turbo_Z's Avatar
I was told if you go much over .620" lift that the valves will start kissing the pistons.... stock internals.
Old Feb 11, 2004 | 04:10 AM
rskrause's Avatar
Moderator
It's not just lift. Piston to valve clearance also depends on the valve timing. IOW, you can't tell without measuring. If you know someone with an identical combo that works, that's another way of knowing if you have enough clearance.
Sounds like a pretty odd combo though, with stock internals and >0.600" lift. What do you have in mind?
Rich Krause
Old Feb 11, 2004 | 09:17 AM
ChuckZ28's Avatar
Im running with .608/.614 lift with no problems but when it was installed I was told that it was very close tolerances piston to valve and he warned me before he even installed it. I think my ptv clearnace was only .060 .
Old Feb 11, 2004 | 11:01 AM
ftransam1's Avatar
Cool thanks guys. I was just wondering
Old Feb 11, 2004 | 11:02 AM
SBCGENII's Avatar
what heads are you running hopefully not stock?
Old Feb 11, 2004 | 11:16 AM
ftransam1's Avatar
yeah they are stock heads for now. I'm only running a .555/.576 lift right now. Didn't really want to go any bigger. Just wanted to know
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
