Manual Rack and Pinion question.
Old Oct 5, 2010 | 01:13 PM
live4therush's Avatar
So i just got a BMR Manual Rack and Pinion setup. Going to put it on right now and just ran into a little dilemna. When i remove the power rack and pinion and put in the manual i'm going to be removing all the power steering lines. What do i do for the power steering pump because i need to have the pulley in place for the belt setup, do they make just a pulley setup that can go there, or do i use a different belt? Any help would be appreciated.
Old Oct 5, 2010 | 05:02 PM
Depends.... are you keeping the AC or deleting it?
Old Oct 5, 2010 | 07:27 PM
I could do either, right now the ac is not functional. What is the easiest way?
Old Oct 5, 2010 | 10:37 PM
With only the alternator, you can relocate it and use a bracket like this (see bottom of page):
http://www.sjmmanufacturing.com/cam_eng_lt1.html
There are less expensive versions available.
Old Oct 6, 2010 | 03:17 AM
Alright sounds good, thanks for the help. Is there any modification to the alternator wiring that needs to be done to complete this?
Old Oct 6, 2010 | 02:41 PM
TDavanzo's Avatar
If there is it should be minor. All that connects to the alternator is the lead line from the battery and a 3 wire (guessing) voltage meter connector for the pcm. Those are all easy things to change/extend.
Old Oct 6, 2010 | 05:12 PM
The actual wiring varies from year to year, and you haven't told us anything about your car. Adding a "signature" is a good idea - year, model, engine, trans and any major mods. That way people can give you accurate answers without guessing.
Here's a 95 alternator wiring diagram, courtesy of Shoebox. He has 93 and 96 LT1 wiring diagrams as well.
http://shbox.com/1/starter_charging_95.jpg
The alternator is even simpler than described above.
Aug 7, 2015 01:26 PM
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Boss002
Jul 9, 2015 03:33 PM
