manual fan switch
Old Jan 10, 2006 | 07:01 PM
scottslt1z28's Avatar
manual fan switch
I have an OBD1 comp tuned by bryan at PCMforless on my OBD2 car..................will my manual fan switch still work right when i put it in??? (i.e.--have a high and then low........or will it function as the OBD1 camaro fans do??? and only on and off)
thanks
Old Jan 10, 2006 | 08:52 PM
Re: manual fan switch
no one?
Old Jan 10, 2006 | 09:19 PM
LT1 POWR's Avatar
You should still be able to turn it on, and im pretty sure the high/low speed will still work right. I never tried mine out when i had my OBDI conversion in there.
Old Jan 10, 2006 | 09:50 PM
well i made the switch........i did it through shoeboxes DYI instructions
Old Jan 11, 2006 | 07:38 AM
It will work the same.
Watch the TTT abuse.
Old Jan 11, 2006 | 02:29 PM
should i use it using the OBD1 instructions or the OBD2 instructions??? (i mean i know both are the same, but the oBD2 just has a couple extra resistors to block pcm signals i think)
use or dont use the resistors??
im sorry i wasnt aware that i was abusing it
Old Jan 11, 2006 | 03:34 PM
Use the instructions that match your PCM OBD type.
Old Jan 11, 2006 | 07:01 PM
thanks, will do
cristian1311
Nov 23, 2014 02:22 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
