Manual fan switch
Old Aug 14, 2003 | 09:59 PM
Bandit97's Avatar
Question Manual fan switch
I read somewhere on here about somone buying a manual fan switch made specifically for the lt1/ls1 to be able to turn the fans on with out having the car get hot first. Who makes it and where can it be purchased?
Cody
Old Aug 14, 2003 | 10:01 PM
Lyle A's Avatar
www.slponline.com
Old Aug 14, 2003 | 10:05 PM
importeater's Avatar
Why pay $70 for one from SLP when you can make one with common Radio Shack parts in about 2 hours time for around $15.. If you want help Id be more the happy to help you through it or talk to Shoebox he is a wealth of knowledge!!!
Craig
Old Aug 14, 2003 | 10:07 PM
Lyle A's Avatar
Yes it is easy to wire but it is easier to install that switch if you are not electrically inclined.
Old Aug 14, 2003 | 10:10 PM
AsianSensation's Avatar
Lengthy guide
Old Aug 14, 2003 | 10:17 PM
Lyle A's Avatar
That's a pretty good set of instructions. I'll use it for the LED's.
Old Aug 31, 2003 | 11:55 AM
Bandit97's Avatar
Ok i hooked up my wires for the manual fan switch and when i throw the switch to one side the fan comes on but when i throw it to the other side, nothing happens. Did all the fans come to where you can set it for high and low, or just certain years? As long as I can get the fan to come on when throwing the switch, does it matter about the other speed?
Old Aug 31, 2003 | 01:44 PM
87transam383tpi's Avatar
u can but a reprogramed comp. for $75, u can have the fans turned on sooner (no switch then), and have rev limiter, speed limiter and all that stuff taken off too.
Josh
Old Aug 31, 2003 | 04:28 PM
Lyle A's Avatar
If you have a 93 then your fans only have one speed. If not, then recheck your connections and the wiring you tapped.
cristian1311
Nov 23, 2014 02:22 PM
slothgrant
Aug 22, 2002 03:01 PM
x7x7
Aug 15, 2002 06:49 PM
sfGi8nt
Aug 1, 2002 05:54 AM
