Manual Bypass to turn starter?
Old May 16, 2005 | 07:19 PM
97 RedSS's Avatar
Will running a single wire to the purple wire to the starter allow me to touch +12V and turn the starter manually?
Anyone ever done this? I want to do a compression check and I am by myself right now...
Cody
Old May 16, 2005 | 07:23 PM
Dave89IROC's Avatar
Re: Manual Bypass to turn starter?
yes
Old May 16, 2005 | 08:04 PM
97 RedSS's Avatar
hmmm...unless Im doing something wrong it's not working for me..I tried with the key on and off...no go..
Cody
Old May 16, 2005 | 08:12 PM
Dave89IROC's Avatar
does it turn over with the key?
Old May 16, 2005 | 09:23 PM
JD95BIRD's Avatar
just put a wire on the purple wire and a wire on the power wire on the starter and touch the wire ends together.
Old May 16, 2005 | 10:34 PM
97 RedSS's Avatar
Sry guys...it was my fault...the rubber groment around the purple wire was allowing me to get a bad connection at the starter..Once I redid the wire it worked perfectly...
Cody
AlaskaZ28
Apr 17, 2015 08:54 AM
eazyZ
Mar 1, 2015 07:12 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
formula79
26
Aug 5, 2002 12:21 PM
