Making your own 383 stroker??!!!
Old Nov 11, 2003 | 09:56 PM
Briank8811's Avatar
I just bought a new engie rebuild kit. What parts would i have to buy to turn that kit into a 383 stroker???
Old Nov 11, 2003 | 10:42 PM
S.J.S.'s Avatar
Huh......if you already bought the kit and its not a stroker kit then you should either return it or sell it and buy a stroker kit dude.
Old Nov 11, 2003 | 10:43 PM
Fatdog's Avatar
Cool
Wal-mart has a book on rebuilding small block chevy engines(Lt1 and Lt4),but dunno if it covers stokers.Hope this helps.
Wal-mart.com
Old Nov 11, 2003 | 10:51 PM
atljar's Avatar
SJS said it correctly more or less.
You can use the rods and the pistons (if they are .030). Then you need to get rid of the 3.48 crank and go 3.75. Also need to clearance the block for the bigger crank.
Old Nov 11, 2003 | 10:52 PM
WheelmanZ28's Avatar
Yea, asking that kind of a question, u DEFINITELY need to do a lot of research.
I'm guessing that u bought just a piston and ring and gasket rebuild kit, not an actually stroker kit. Did it come with a crank? We need A LOT more info before we can help.
Old Nov 11, 2003 | 11:00 PM
S.J.S.'s Avatar
Let me know if your serious Brian. I didn't know crap and just threw in my stroker this pass weekend and fired her up yesterday. Like my machinist told me, "80% of building an engine is research and planning." I did so much research I have 2 binders full of information from guys here and elsewhere. I call them my bibles. I will tell you onething though. You will have to set your budget at least 2k more than you expect. Lots of added costs when moving up to a stroker. Upgrading and stuff.
You're not telling us enough. Seems like your just entertaining the idea.
Old Nov 12, 2003 | 06:10 AM
Briank8811's Avatar
What im basically asking is to compare parts of a full engine rebuild kit minus crank to a stroker kit. What parts are different between the two sets? I know the crank is, my 350 is bored .030 over and im sure the pistons are different also? So the answer im looking for is what other parts would i have to buy to switch to a 383 94' LT1? Remember i just bought a FULL engine rebuild kit "STOCK" for my 350ci LT1. Thanx for all replies!
Old Nov 12, 2003 | 06:51 AM
Smoke T/A's Avatar
Yes you can use the rods and pistons for a 383 but depending on the piston the skirts might have to be machined to clear the 3.75 stroke crank. Some clear some don't.
Joe
Old Nov 12, 2003 | 07:36 AM
OldSStroker's Avatar
Joe
Guys, a piston and rod for a 3.48 stroke (350) will stick out of the top of the block about .135 inch (zero deck) when used with a 3.75 stroke (383) crank. Chevy used 5.565 long rods in the 400 with a 3.75 stroke.
Old Nov 12, 2003 | 08:57 AM
grendal's Avatar
You can use 350 rods, but your pistons have to be made for a 383, or vice-versa.... Like has been said said -- the pistons would pop up past the deck and smash into your heads. Something has to give!
-Michael
Old Nov 12, 2003 | 01:03 PM
atljar's Avatar
Hmm learn something new everyday, but it does make sense if i would have taken the time to think about it.
Old Nov 12, 2003 | 01:17 PM
Briank8811's Avatar
So i should be able to use everything im my rebuild kit except the pistion....(i was looking into forged anyways).And i would need to buy the 383 crank.....Right? The key component that makes it a 383 "stroker" is the stroke of the crank. Correct me if im wrong!
Old Nov 12, 2003 | 01:19 PM
hsyr's Avatar
Save yourself a headache if your going to build a 383 and return that rebuild kit. Buy a 'complete' stroker kit. You really need to set some goals for yourself. Is this car going to be a daily driver? What HP levels are you pushing for? Staying N/A or are you going to use Nitrous/Supercharger/Turbo ? If you go stay N/A you can settle for cheaper internals to keep the cost down but if your going nitrous/boost you will want to get beefier internals so your motor lasts. Also, what kind of RPM do you want to turn? If your going over say 500HP goal you might want to look into some splayed 4 bolt mains too. So do this, find out your goals, return rebuild kit if your going with a 383 or 396, then reasearch what you will need. Do it once, do it right!
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
