what tranny fluid do you use in your 4L60E?
Old Nov 11, 2003 | 11:37 AM
SpectacularZ's Avatar
as the title says
Old Nov 11, 2003 | 11:46 AM
S.J.S.'s Avatar
I use Penzoil ATF with Dextron III. You shouldn't use synthetic fluid in your trans. The transmission, unlike the motor needs a litle bit of friction to run right and to get the most life outta it. I was told by all 3 shops I got quotes from before I rebuilt mine in Aug. All 3 agreed that I should run regular oil. They also mentiond something about the ingredients in dino oil.
I know a lot of guys here are running synthetic oil in their trans and I'm not saying that its wrong. But after I did a lot of research on the subject before spending 2k on it, I found that the score was 3-0 for dino oil.
good luck
Old Nov 11, 2003 | 01:22 PM
VegasZ's Avatar
Valvoline Durablend Dextron3/Mercon5. Costs a little more but worth it. Not all places carry it so call around. I found it at a local Pep Boys. Mercon 5 is the highest rating available.
Old Nov 12, 2003 | 07:59 AM
thanks anyone else want to chime in?
Old Nov 12, 2003 | 08:37 AM
TedH's Avatar
I have whatever the local chevy dealer put in mine. Non-synthetic. My transmission will slip if I use synthetic.
Old Nov 12, 2003 | 10:38 AM
Patman's Avatar
I also prefer to run conventional Dexron III in there. There is just too much uncertainty with running synthetics in the 4L60E, I know at least one of the aftermarket torque convertor makers recommends against using synthetics.
What I like to do is get the fluid changed every year, but I alternate methods. One year I get the full flush done and then the next year I get the more traditional "pan drop/filter swap" method done (which only replaces about 40% of the fluid, but at least you get a new filter and pan gasket, plus they clean the pan magnet)
I figure this method should help my trans live until hopefully the 150-200k mark. It's at 95k now and still works perfectly. I bought the car used with 56k on it and know for sure the fluid was changed at least once by the previous owner too.
Old Nov 12, 2003 | 11:40 AM
94_Camaro_LT-1's Avatar
Ditto that one, Penzoil DexIII here too
Old Nov 12, 2003 | 11:43 AM
madwolf's Avatar
Tritto that.
I've heard some horror stories about synthetic and the b&m trick shift fluid, so I'd stay away from those...
Old Nov 12, 2003 | 01:03 PM
FastZinTennessee's Avatar
Valvoline Maxxlife. Works a whole lot better than the Mobil 1 I had in there before.
Old Nov 12, 2003 | 01:33 PM
TMD95Z28's Avatar
ditto here, i used that one too
Old Nov 12, 2003 | 01:55 PM
Waistin_Rubber's Avatar
Royal Purple ATF...It hasn't even been 500 miles and it's getting checked this week to see if the fluid has been leaking. I'll post again with a yeah or nay.
I had the dealership stuff in there for about 50,000 miles no change or filter drop or anything. Drove it hard didn't lose a drop
Parts Wanted
May 1, 2016 10:25 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
