make your own delteq?
Old Sep 11, 2007 | 06:42 PM
dangalla's Avatar
i just aquired 8 coils from a 5.3 motor from a yukon i just swapped a motor in
is there any way i can make this into a delteq system relatively cheap
Old Sep 11, 2007 | 06:44 PM
maybe2fast's Avatar
the coils the system uses is from a Cadillac Northstar. The ICM and Starndard GM two post coils. Not sure how they combined the systems.
Old Sep 11, 2007 | 09:03 PM
bingo's Avatar
Do you mean a LTCC setup?
Old Sep 11, 2007 | 10:59 PM
raroz28's Avatar
You would need the opti box.... If you could get that, all you'd need is the ICM, coil packs and all the wiring.
Old Sep 12, 2007 | 12:48 PM
Can't build a Delteq with those coils. Delteq functions in waste-spark mode, firing two cylinders at a time - one on the compression stroke and one on the exhaust stroke. You would need 4 dual-tower coils.
As noted, you need to duplicate the Bailey LTCC. You need a full 8-channel direct fire system to support 8 coils. One way to get around the LTCC box.... buy a MoTeC M800 ECU and add their IEX 8-channel ignition driver. About $4,000.
Old Sep 12, 2007 | 02:46 PM
dangalla's Avatar
yeah... so ill just scrap that idea
thanks for all the input guys
Victor Lamb
Aug 26, 2017 02:52 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Ari G
Dec 11, 2014 03:21 PM
siguy
Nov 27, 2014 10:07 AM
